FMIC pics needed please.
13.robb
I have deleted the factory water to air intercooler set up due to a bad pump, I am going to install an air to air set up, I was wondering if anyone has any pictures of a finished install.
I must be able to keep the a/c operational, i live in vegas and drive almost everyday. Thanks. Robb
nallj92
Re: FMIC pics needed please.
i have some ill get up later.. just put it in last week W/AC and all
edit. heres the pics, went with the ebay core, the 3 inch thick one, with a pipe, kit.
couple things, i left about a finger width between the core and the a/c , it cools it great with a taurus 2 speed fan, the pipes were close to the crank pulley but will work. I had to notch the latch frame to fit. ditched the PS cooler and reloated trans cooler to underside of frame behind driver seat with a fan. i cleaned up and edged the steel with some vac line so it was a bit nicer. i had to trim the bottom corner edges of the grill to fit the core, it looks nice and is not even noticable.
weight- 40 lbs of water to air stuff, and 20 lbs of are to air, so about a 20 lb loss of weight, which i like.
13.robb
Thanks for the responses, i checked out epix's, my internet blocked maitai's, looks very effecient, on epix's were you able to keep the a/c?
skwayb
NWSTP
nallj92 said:
bump for my uploaded pics above.....
I pretty much followed Epix setup.
Man mine looks so similar to yours Nallj92... except I have 3" Tubes.
nallj92
paul, mine is 3 inch pipe also, i modeled mine a bit after yours, but had to fit it different for my AC hoses and heater box! your engine bay does look good! when are we going to see some numbers from the truck?
skwayb
NWSTP
Thanks TYTILIDIE. Some of it was done by the original owner but I have done a lot of work to keep it look as good as he did if I made any changes like the A2A.
I am going to the Turbo Thunder Event in July so I should hopefully have some numbers then. I still have a lot of tuning to do and get it to pass emissions. It fails the idle part. Tried all kinds of things and it just barely fails. Have a few more things to try to get it to pass.
Don't expect the world out of it. It is a stock motor (heads, cam, pistons, rods, etc.) I am hoping I can get it in the mid to low 12's if I am lucky. But since I haven't ran it yet I am thinking high 12's is all I will get out of it until I get kinks worked out. (Tranny tuning, Wastegate adjustment, methanol tuning, etc...)
MAITAI1993
DON'T MAKE ME SLAP YOU.
TYTILIDIE said:
Your truck makes me sick Paul :lol:
sick like puke :sick: pauls truck is ok I guess if you dont wann cut the core support out do like I did 2.5 inch pipe you are not gonna gain shit out of 3 inch unless you have a huge turbo and still wont notice shit
here
skipztt
boost
here
:tup: good job MAITAI1993!!!
thats the way i was gonna do a fmic, if i decided to go that way. but i decided to keep the stock ic stuff.
MAITAI1993
thanks I try
