Foamy coolant in Upper HE
Ozrein
BC Syclone
Question for you guys, this may be a stupid question but I'd rather ask than not.
I've noticed that the coolant in the upper heat exchanger is kind of foamy. Now I checked both before I started the truck and both were fine, 'clear' coolant, no foam. I ran it for a few minutes then checked both again. Upper H.E. had foamy coolant but rad was still fine.
What would make this happen? Any tips would be very much appreciated. Thanks in advance.
bezerk
Re: Foamy coolant in Upper HE
you mean the a2w intercooler right? you prolly got air in the system, kinda hard to get that air out..
Mad Mike
SYCOSIS
The intercooler and radiator are separate systems other then sharing the overflow bottle. Do you have the stock metal lines or heater hose? Check for kinks in the hoses and recheck all your hose clamps. You may have a leak somewhere allowing air in or you have air pockets trapped in the lines or intercooler. Loosen the intercooler and tilt it in different directions to remove air pockets.
