Falco
Howdy,
I've finished my new electric fan installation approx. two weeks ago. I've already accomplished a little testing in the mean time, too. The fan is for a 95' Ford Taurus 3.8L, I got it brand new for $100. Previously I've used a much smaller fan from a VW, and I had cooling issues, not serious ones, but after a run my temps kept rising, the fan couldn't stop it.
Now with the new fan my temp never goes above 165 , whatever I do, high 80's outside. During cruising it's below 160F. Currently I'm using a manual switch right now and usually I keep it running on high speed all the time. I plan to use like this for a while then I'll see...
I like the install too, it's looking quite OEM, both the lower and upper shrouds are in place.
I've also measured the current requirement of this fan. It draws 37 Amps at startup and 18-20 Amps at full speed. I'm using a 70 Amp relay and a 50 Amp fuse just for security... I've heard some serious numbers posted about these fans, that's why I measured it.
I've made up a new cooling page at tragacs.com as well:
http://www.tragacs.com/cool.html
Peace,
Peace,
