E.Murray
Finally got to the point of buttoning everything up after my turbo porting, WBO2 and boost gauge install, valve seals, and swap from stock to Forge Billet w/g from SportMachines. First run, everything seemed fine, but was a bit rich and only hitting 7 psi. Shortened rod a couple turns, dialed fuel back a bit on the TurboTweak chip and was at 10 psi max. Went to shorten the rod again and ran out of travel after 1.5 turns. It looks like there should be plenty of thread left (see pic), but it definitely wouldn't go anymore. I even pulled the end of the rod off to verify that it should go and re-threaded it, but that's all she'll do. I went out to run it and hit 13 psi with lots of stuttering at max boost. The waste gate has the stock 14-18# spring (according to SportMachines). It looks like I should be able to adjust it farther, but it doesn't go. Also, it seems like the hole lined up pretty well with the w/g arm without having to tug on anything. Should it go shorter?
