Fouled spark plug?
bjk_typhoon
1993 Typhoon
Driving home last night I recieved an engine code 45 (running rich). I have been having issues with getting my Ty to run right after my build. I am still in the process of getting my datamaster but I am fighting issues with getting my Phil Long 50#er chip to work correctly. I have been swapping between the Phil chip and an old ART Pitbull chip. I know I can back off my fuel pressure (currently set at 40psi) but I am fearful of KR under acceleration. Any way here is plug number 1 after about 800 miles. Do I change them out or not?
Loeryder
Re: Fouled spark plug?
If you are running an old ATR chip with the 50# injectors that is a problem right there.
Last I heard ATR didn't make a 50# bin.
It is probably dumping way too much fuel because the injectors are so much larger and the chip doesnt know the difference.
bjk_typhoon
1993 Typhoon
Believe it or not it runs better on the ATR chip than the Phil chip. Yes I know that there are issued that need to be corrected but on the Phil chip it loads up so bad it will hardly run.
