found waste gate overboost code in ecm but no light
atkonkler
Is this your bush?
i found this code tonight waste gate over boost, after doing a tune up and replacement of fuel filter. anyone got any ideas? after tune up did notice not as snappy! had ngk plugs/vpower in it and put original 42 delco plugs in it? stock set up no big mods besides cold air kit from rpm and reroute of intercooler hoses and hotwire intercooler pump! if you got any idead where i should start wit the over boost let me know>
Re: found waste gate overboost code in ecm but no light
Are the plugs cr42ts? Some places will try to give you r42ts. I would not gap the plugs to 0.025 on stock motor 0.035 or 0.032 is fine. You may be just setting a flag for over boost but it is not in the over state long enough to set a code. Some properly running SyTy may set the overboost flag from time to time, and may be considered normal operation.
