if you do not use the pulsator and use a rubber hose will you fell alot of pulations on the fuel rail ? mine pulates like crazyghettosled said:did you re-use the pulsator when you did the fuel pump swap or the rubber line in the kit? FYI, many aftermarket regulators drop the fp to zero with the pump off so i dont think it is a serious issue. As long as you have adequate pressure and flow under hard throttle, it shouldnt matter.
scotts4 said:if you do not use the pulsator and use a rubber hose will you fell alot of pulations on the fuel rail ? mine pulates like crazy
