Frame pads removal question
sy1907
SYCOTIC
Guys, anyone have any luck in getting the frame pads out without taking out the front diff? I can't seem to get a wrench on the nuts on the back of the bolts because they're boxed in by the diff, frame, and frame pad itself. Any jimmy rigging ideas would be great. TIA!
denny
Re: Frame pads removal question
I did my driver side about 2 months ago, it took about 2 days.
I think I can do it now in a few hrs, I remember sitting looking at it for hrs , its seems impossible.
Here is how I did my driver side
I bought a set of long box end from autozone ,cheap , and one cheap 15 double end.
cut the one 15mm to about 1 inch long.
dont forget rachet wrench are your friend
take out the wheel/ fender well
3 bolts holding the frame pad
1.get the top right bolt thru the fenderwell
user the cut 15mm wrench to hold the bottom and user the rachet wrench on top, easy
2. Bottom left
You probably need to take out your cac radiator ( I have A2A)
If you lay under look between the diff you will see a little space and the left bottom nut.
If you don't see it, look again, its there.
Use a box end to hold the bottom and you can user rachet for the top.
3. The middle bolt, the hardest
The same way you get the bottom letf, if you push the boxend up you will get to the middle bolt. It look impossible but a long box end reaches.
It would be nice if you can get someone to help, because you have to get the top true the fenderwill and hold the bottom from under.
I had no help so I had to jam the boxend and go around and get the top with the rachet wrench, its a bitch because the boxend would fall off.
VermontTy
Support Our Troops
Don't be a puss Dan....move the front diff! It can be done without as posted above, but pulling the propshaft, unbolting both CV's and unbolting the rear diff mount so it will swing down a little takes about an hour. Made it a whole lot easier. Also, I bent the snot out of a cheapie 15mm wrench to help things along.
nallj92
just give up and buy a cobra! i have no other help, stock mounts rock!
I dropped down my front differential down a few inches to get to the motor pads. I don't remember the specifics as I have blocked that day out from my memory.
keith455
Average Joe
Staff member
I think i pretty much did the same as denny. on the reinstall i crazy glued the nut to the wrench. Only took me about 3 times of dropping the nut to figure that one out.
myclone
A layer or two of masking tape around the nut then forcing it into the wrench works too.
