front coil over questions
syty9933
i am upgrading to the front coilovers on my truck, and think im goin with the qa1s. My first question is can you adjust the height with coilovers? . Second is why do people upgrade the control arms? and do i need to do it if i upgrade to coilovers?
4C FED
Absolutum Dominium
Re: front coil over questions
cool , how do you adjust the height with them?
There is an adjustment ring & lock ring at one end of the spring.
to adjust ride height, loosen the lock ring and turn the adjustment ring tighter or looser to adjust to desired height. Tighten lock ring.
syty9933
sweet thats all i need to know
syty9933
actually what are the part numbers for the qa1s and the springs that go with them?
syty9933
whats do i need for a budget job, just the shocks and springs? and from where?
EcSy#2671
Si vis pacem, para bellum
I think Mike from RPM will sell you just the Springs and Coil overs for like $550 don't quote me just give him call if Turbotime is unavailable.
TurboTime's and RPM price are competititve with what you will see in Summit racing for QA1/Hypercoil spring. The springs are 1/4 "smaller diameter than what fit them normally and require the coilover cups to be machined down.
