YES, I don't recommend this as a fun thing to do for anyone.. I just got finished swapping out a front diff and it sucked.
It could have been because it was the first time i've removed a front Diff but it was a Pain.
After messing with it for about 3 hours I finally decided to pull the pass side tube, driver side axle, yoke and disconnect the driver tie rod, pitman arm and idler arm from the center link and moved it out of the way.
Then the Diff kindof just fell out.
Putting it back in was OK, but getting the bolts and bushings to line up were a pain and required a little "convincing" to line up.
I'd only do the bushings if they are totally shot, like the truck i'm talking about or you have the engine out and it's easier to get to the diff..
Have fun.
