Front end Limiters
alwayscode390
pppssssshhhhhtttttttttttt
Re: Front end Limiters
I didnt even know we had stock ones ... I need to go look.
What part of the suspension is it bolting to, the upper a-arm? What part is it hitting against? ---
SYCLONE#1531
'MOFOFAST
Front limiters and lift bars aprox 8 to 10lb launch Limiters were set fairly loose in pic. Rubber bushing was just making contact.
Stock suspension with no limiters.. 8 to 10lb launch
Sean Krupa
Moderator
I just put the same Limters SYCLONE#1531 has on. Haven't launched it yet though. But I have like a 1/2" space between the rubber bumper and metal contact with the wheels on the ground.
Gt_Sgt
self diagnosed INSANE!
Ok I replaced everything with enegery suspension, also installed the same bump stops as above. I have done only 35-40 "10 lb. boost launches" an.:lol:d have a daily driver. There has been no harsh side affects with hooking up, wheel hop, lack of traction, ect. Have been very pleased. I have stock ride height, stock overall dia. rim/tire combo, factory backspacing and off set. I have had no troubles with traction running Blizzak ws 70 Studdless Snow tires. yes it launches well in snow and better on dry tarmac with VH sprayed fresh on track. Almost no tire spin, ALMOST! hope this helped
Damian
Look on the rear under side of the upper control arm, there is a the stock bushing. Or jus look on top of the control arm for a nut and bolt. Take that on out and boot in the new one. I replaced mine without even pulling the wheel off. Turn the wheel all the way to lock and go in from the rear.
