front liscense plate
Jersey 91/93
NASTE Member
Re: front liscense plate
Get Morgan's brackets, plus a pair of 1/2" vacuum line caps. I also suggest getting a strong metal liscence plate frame, since the thin metal plate likes to flex too much by itself.
The velcro is going to do just as much damage as drilling holes in my opinion. At least with Morgan's brackets you just have holes in the bottom of the bumper where you can't see them.
MaxTTY
Ty Sellout
Thanks for the suggestions. 1/2" Vaccuum line caps? What are those used for... "bumpers" for between the plate and body?
Jersey 91/93
NASTE Member
Exactly... more specifically they serve as "bumpers" between the nuts and your plastic painted bumper.
SEL777
One of 101
I took some thin foam with PSA and put that on the back of the plate where the plate may touch the bumper and added a thin rubber washer behind the plate so I did not have to bend it around the front of the bumper. I had the holes there already. I would also suggest a plate holder too so the plate does not move. It almost ripped the plate off my Ty first time through the automatic washer.
MaxTTY
Ty Sellout
Excellent, thanks for the info guys!! Looks like I will have to get the mounting kit on order.
supersports10
fyi...... if you vehiecle came from the factory without a provision for a front plate, you dont have to have one....it's a law.
Norm
Not where I live it isn't. Under the motor vehicle act, if there is a 2 plate law you must have a plate, putting one in the front window doesn't qualify either. You must have 2 plates other wise it's a ticket.
