Front main fell off. WTF
DanenGraham
Big in the rear
Tonight, is the night, to end all nights. I finally got the front drive shaft out of the way, and droped the oil pan. I found the front main just sitting in the bottom with the two bolts and washers. The journal looks find on the crank, no scars or anything. :tup: :tup: :tup: :rock: :rock: :rock:
So now i get to buy a new bearring and slap this bitch back together. But i have one Q.
In your opinions do you think the front seal is F'ed. It was a decent amount of oil leaking out of it. If I put the main back on will it hold it still enough that the seals will reseal, or should i just rip it all apart and put in a new one???
MikeRenz
not stock
a new seal isn't much money...why bother using your old one. You're just asking for it to leak if you reuse it.
leroy
Wow.
I agree. Replace it just because it's cheap, and there is quite a bit of labor involved if it leaks.
What happened to the bearing? If it got hammered, I'd be concerned about fragments throughout the engine.
Make sure everything else is torqued under there.
Jim
myclone
Like was mentioned make sure the rest of the fasteners are in the bottom end are torqued down correctly. Also, since the front main journal feeds the first rod bearing I think I would be concerned with what the first rod bearing looks like since without the front journal in place it was being supplied with little to no oil.
Dont reuse a leaking seal...especially one that costs $3 and it easy to replace as the front main is.
93ty475
Re: Front main fell off. WTF
your front main cap was in the oil pan? it drove like that? wow...i would plastigage at least the mains if you can...i agree on replacing the seal....how did you do all of this without yanking the motor?
DanenGraham
Big in the rear
I pulled the front axle (not the drive shaft) and ripped the front end apart, then the oilpan just falls right out.
Jimmy
Banned
Someone needs thier ass kicked Danen. :rock:
I'd be madder then hell if my build was stupidly done.Who built it?
DanenGraham
Big in the rear
yeah, but the thing is the motor had like close to 5k miles on it. If it was the shops fuck up it should have fucked up sooner than that. The shop that did my motor did help me out once already. (put motor in truck, oil pump had a problem, they took my truck and droped the pan fixed the pump all for free, 8hrs of labor they said)
I hope i didnt bend or weakin the crank, driving it with only two mains, that cant be good.
ghettosled
SYTY SUPERSTORE
i would be conserned about the main cap having lost its register in the block, which will throw off the line bore/hone. If it is not consistant with the other caps, you will see premature wear on the front main bearings. Unfortunately its kinda hard to do any sort of measurements with the motor in the truck, so i would just say run it and hope for the best :)
