front windscreen seal
Quickstop [UK]
Combating adversyty.
I'm chasing a leak and need to replace the front seal on the windscreen. I got one from LMC and had it installed but the installation was a bit of a mess. Also, it looks like there are two styles.
Does anyone know where I can get the correct rubber seal from? The one from LMC was the wrong one.
The correct style has a 1"wide strip that covers the windscreen and the body about 1//4" either side of the seam. It's T shaped all along.
The one I have looks lice it is recessed and flush with the window. It is W shaped or something.
Thanks,
Mark
cat-vi
Ty Wannabe
Re: front windscreen seal
Thanks,
Mark
I've just replaced the windscreen, this was glued in, I doubt that by replacing the rubber seal around the windshield will rectify the leakage, I thing you be better off by removing the windshield (carefully to avoid it to crack, did not work for me:oops: but should be fully possible with the right tools) clean up the "frame" and use some good coating, the seal around the windshield was applied after the windshield was innstalled, I had to adjust slightly at the two plastic pieces at lower part of the windshield to maintain a good pressure against the "rubber seal" at upper side of the windshield. The rubberseal was ordered for a blazer (since my truck is a blazer!?:rotf:) I had a friend to give me a hand who allso got a electric driven thing to add the glue on with very fast and accurate, this could ofcorse been done by hand, but be aware that the glue start to dry after just two minutes or so, after that it wont bind as well as it should and the risk for a leak will be there quite soon, when we added the glue it was quite thick, like abt. 25 - 30 mm but not as wide (abt. 10mm maybe)
bezerk
correctly, normal the ''seal'' is just something to look better, they are glued in..if you want to know, you need a pressure washer and put it on closely (with the seal removed) and check for leaks.
altough special shops (as we do too) have a tool to remove the windscreen again and glue it back in..
No i haven't fixed the sy yet....:p
warmpancakes
the aftermarket ones are wider than the GM piece to cover scratches from windshield removal
V
15957963
disclaimer: I have never purchased this part...verify before ordering.
Quickstop [UK]
I bought this and it is the correct one.
:tup:
warmpancakes
Just a FYI for anybody who cares GM has made this Part obsolete but there is still stock remaining
15957963 is correct for 91 sys and 92 TYs the part number changed in 93 (according to my parts guy)
30.74 plus tax is list price
Rexxenexx
Yep this is the correct piece as shown in post #7. Got it last week from GMParts Direct. On my Ty I have a universal that's coming out AND is HUGE compared to the OEM.
So you guys (without leaks) just peeled the old one out and pressed the new one in?
