NE FS: 4 bolt main engine block
tbauer03
TRBOBOX
This is my last engine block. Detonation killed the bearings and metal was ran through it. It is currently 30 over, my machine shop said it should be fine at 40 over but I elected to go with a different block and we never sonic tested this block.
It has been drilled and tapped for pro gram 4 bolt splayed caps.
Make an offer and pick up only.
If nobody is interested I will just make it into a coffee table. But figured I'd see if anyone wants it first.
I am in Omaha, NE.
tbauer03
TRBOBOX
Re: FS: 4 bolt main engine block
This was the old block I pulled out over a year ago. It's just been sitting around ever since and I'll be moving soon so I figured I'd see if anyone wants it because it might still be worth using.but If not I'll try converting it into a table for my man cave.
Like this
pearl91chevy
Did that with my old 4.3 block.. Seems to be all its good for haha
0966Sy
Code what?
Nothing wrong with a .040 over 4 bolt main block. I have one .040 with straight 4 bolt caps I'm considering selling locally. It's ready for assembly otherwise I'd like to have a half block fill done and recheck the line bore and push it in the Typhoon with the BS3. If the .030 is clean it could be redone at .030 over
