Borla Catback exhaust for a Syclone. The have been long discontinued, the last production was over 10 years ago. The original Borla cataback exhaust had a 2 1/2 inle, with a quick transition to 3" piping, it enter the muffle and split out to 2 2 1/2" exhaust pipe.
I got this used in 2002, from a FL Syclone, it has never been in the salt/winter. When I got it, it had the 2 1/2" adpater removed. I actually had the 2 1/2 reattached to install it on my stock DP & Cat. I then had an exhaust shop put 3" pipe pipe put back in its place. The pipe is a 3" OD, (it slip[ped into my Cat & test Pipe) I still have original 2 1/2" adapter. This can be seen in the second picture.
When I had the exhuast installed, it was crooked. The exhaust shop welded on regular exhaust hanger to stabalize it. This did work, but what I didn't realize until I pulled it out today they cut off the original bracket. This hangers on the pipe can be seen in the 3rd picture.
The bottom of the Borla tips have some scratches, you won't see them when install (unless you look up at your exhaust) The scratches happened on one the trip trip my Syclone took on a flatbed tow trucks.
Over its in good shape with 3" slipping fitting exhaust, you might want to have an exhaust shop help tweak the pipes. I personally liked the way it should with the stock downpipe/cat, but I didn't care as much for it with the 3" DP I have now. It seem to have some resonance to it.
$275
$275
