FS C6 brake kit Almost complete
Sy-1177
Turbo Inside
Well, I started putting this kit together last fall but this was before I decided to sell Sy-1177 which it was going on, so i'm just gonna try and sell it for what I have into it. I have the front and rear calipers and brackets from a C6 Vette; both front and rear rotors that were new take-offs; and a Renz-Fab installation kit for the front. I'm still missing the mounting kit for the rear, and brake pads... thats it! The calipers I was told came off of a 10k mile car. They look good but could use a repaint/powder coat. One rear seal is torn as well but those are ~$15 bux from the dealer.The front rotors measure 12 3/4" and the rears measure 12". I have around $600 into this so far so i'd like to get close to that out of it. So right now the price is $600 + shipping. I will drop the price depending on the intrest of this stuff.
RenzFab
sales@renzfab.com
Re: FS C6 brake kit Almost complete
fyi thats a Stainless kit which is the higher dollar version, and one of only 4 or 5 that i made.
Sy-1177
Turbo Inside
do these work with stock wheels or would I need to get a bigger size?
I'm pretty sure you need at least 17" or bigger to clear. I know it doesn't look like it in the pics, but these rotors and calipers are quite a bit bigger compared to stock.
hatrik8
I'm not sure. I always thought c5 and c5 z06 were the same except z06 came in red (I have c5 z06 calipers on my SY). I guess c6 are the same also and c6 z06 are the monster ones....
GarnetTy1473
C5 calipers are the same between the reg and Z06, only the Z06 were red and said Corvette. On the C6, the Z06 is the monster 6 piston caliper. These look just like a C5 Z06 caliper, just different color. However, IIRC, easy way to tell is the fins on top of the caliper are pretty much non-existant on the C6. Where they are pretty pronounced on the C5. The only C6 calipers I've seen are silver. Haven't seen blue ones before.
Link to my C5 Z06 brakes, which isn't the best, but you can see the fins on top, which aren't on these, indicating that these are C6 brakes.
http://i101.photobucket.com/albums/m52/jjnance/Ty 1473 Pics/27729624918_ORIG.jpg
TYHOGG
Weren't they blue on the z06 with the special commemrative edition with the blue paint and the center of the hood was silver with a red pinstripe outline?
Sy-1177
Turbo Inside
I think these were painted blue. The paint is flaking off in a couple areas from brake fluid, that why I think that.
I may sell parts of this kit seperate if I see enough intrest that way.
stashisclay
i want to upgrade the brakes on the truck, but I want to keep the stock wheels.
Sounds like I'm SOL on this.
Sy-1177
Turbo Inside
will this fit a 93 blazer 2wd?
I don't see why it wouldn't, but I honestly don't know. I believe that the 2wd and the 4wd take the same caliper application from stock so they should have the same mounting brackets and all.
