Syclone#2960
What ever it takes!!
I'm selling my long block with about 3,000 miles or less. This motor was running 10.40s @127 mph at a local track with our annual 2012 syty meet at LRD.
The motor was pulled a week later to begin the V8 swap. This same exact combo (chip,turbo & cam specs) is installed in my ty.
Block and heads painted with POR15.
The block is from RPM bored out .040 and was cryoed.
The stock crank is also cryoed.
The pistons are from diamond.
4 bolt splayed caps.
eagle rods
ARP everything.
All the good stuff.
Vortec heads ported
latest designed beehives and titanium retainers
RPM intake
everything in the picture.
Im going to include the adjustable chip, 75lbs/hr fuel injectors and modified ECM.
I know there is a lot left on this tune because the WOT timing is only at 17* which is relatively low for running vortec heads...Im pretty positive I would have ran 10.0s with 5-6 degrees of more timing. My turbo lag was very bad with this tune. I added 5-6* base timing in the ty and the lags is gone.(im pretty confident it will run high 10s at our next meet)
I don't need to sell this motor, I could always keep it as a proven spare in case ty motor goes.
You are welcome to install this motor in your truck at my shop. I can help you dial it to give it a safe a/f ratio. You wanna run 10s? better have a built tranny and a 67mm or larger turbo.
you can email me at brucechristiansen @ ureach.com...my PMs are always full.
I think $7,000 is a fair number to ask...OBO is always welcomed.
Here are some pics of the motor today. It is stored in my shop with 2 trash bags/plugs wrapped around it.:tup:
http://s148.photobucket.com/user/sycl-ownz/slideshow/syclone V6 stuff
eagle rods
ARP everything.
All the good stuff.
Vortec heads ported
RPM intake
