Fuel and Braided line, what Types?
syntax
Is your normal run of the mill braided steel AN line made to run gasoline and race fuel through it constantly? Or should I be looking at some of the Teflon lined Braided Line specifically made for fuel, any thoughts on this? I have heard periodically from people that Normal AN line is not designed to be a fuel line, any truth? or nonsense?
ziembic
Re: Fuel and Braided line, what Types?
Normal braided steel fuel line from summit or jegs is fine. You need the good Teflon stuff for alky because it corrodes the steel.
Syclone#892
http://www.pro-touring.com/forum/showthread.php?t=62575
Check that post out. I will be replacing all of my braided fuel line once the truck gets out of storage.
The problem I noticed right away with the braided line was that the truck always smelled like fuel especially if it sat in the garage for a couple days, I have since found out thats the braided line sweating.
I had my return line rupture after I tugged on it slightly couple yrs ago. I thought it was odd because it should have been able to take that but never looked more into it.
My line was summit brand, I will be either getting some teflon lined stuff or seeing if I can get some hydraulic hose that can last as I have all the tools and fittings to make those up nicely.
Good luck in your search :)
nallj92
why not just run larger solid lines with braided ends for connections? anyone done this?
syntax
i want to but the typical tube to an adapter says its for low pressure applications so i dont know where 50psi efi falls.
Z SKI
Good find guys.
Teflon lined hose for me in the future.
See ya,
Syclone#892
Is that websites prices right? $36 pr foot for -10?
Thats extremely expensive, maybe they have the decimal in the wrong spot?
I can get parker teflon lined hydraulic 5000 psi hose for a quarter of the cost and have nice crimp on fittings etc.
I just dont see the need to pay that much for it :roll:
It's just a six
Super Member
You can get all kinds of hoses cheaper.
It probably is not as light though.
These are the hoses that Nascars use. So that kinda tells you it's got to be one of the best.
Nascar teams do not skimp when it comes to quality.
