Re: Fuel cooler ?
A1000 to what size lines? You will have that type issue if you have that large of a pump on small lines. The pump needs flow to cool, so that means the return line needs to be "big" also. I thought you could submerge those pumps also.:2cents:
You will have pump overheating issues if the feed line is not large enough or if the fuel cavitates through cheaper fittings (Aeromotive recommends their full flow fittings to prevent cavitation). On the output, the size of the line to the regulator is not supposed to matter significantly as the pump can handle the pressure on the output, although Aeromotive does recommend a large return line after the regulator.
The older pumps were external, not sure if they can be submerged or not. I do know that guys will send their pumps back to get upgraded internals. If internal is an option for you you may be able to send it back and get it updated/upgraded.
Doesn't matter how big or small the return line is. If there is a pressure drop across the regulator, which there HAS to be or the regulator can't control pressure, the return line is big enough, and is not 'generating' heat by causing additional pressure. The majority of the heat is from trying to force too much fuel through the regulator because the pump is way too big for most part throttle operation. Hence the controller.
NOW, having said that, a larger return line has more surface area which WILL add to the cooling effect by increasing the area that is exposed to ambient temps for cooling. But it's under the car, which is plenty hot. Usually just from the radiated heat from the pavement. So are you heating, or cooling the fuel by increasing the return line area.?
Something to think about.
I don't think there is a significant amount of heating due to pressurization (PV=nRT) of the fuel. The majority of the heating comes from the fact that the unused fuel returning to the tank has been heated in the engine bay. This is particularly true during part throttle. Plastic and rubber fuel lines don't have much thermal conductivity so once the fuel gets heated it starts a cycle where it gets warmer and warmer with each pass through the engine bay.
Can't see your (Pics) link not working?
I think you are referring to a Cool Can?
I really think Cool Cans are for a Carb setup not EFI type fuel system.
The pump controller is the way to go on an Aeromotive system as stated by Canadian. It doesn't decrese voltage it changes the Pulse Width to control the pump and slows it down or increases for demand. This keeps it cool. $300. approx price. There is also a wide open throttle or race tap on it you could hook it to a hobs switch or a WOT switch somehow on the throttle linkage or just a simple switch to flip when you race to get full on.
The controller is supposed to be the way to go, but it is not cheap. I decided to get one for the Aeromotive Eliminator I have on the Sonoma. I got it because I noticed that after a 20 minute drive the fuel cell was pretty stinkin warm to the touch. I haven't installed it yet... and probably won't get to it for a while... but if that doesn't do it I will get an in-line fuel line cooler. Do they make one in -10 AN? :tup:
Oh, one other thing. Do you have a filter before and after the pump? Originally Aeromotive recommended
NOT installing a filter before the pump and somewhere along the line they changed their position and now sell a high flow filter for before the pump too. Not sure if it is really necessary or if they just want more $$. Stuff aint cheap.
