Fuel in my oil!!!
AlaskaTy
Okay, so I've been gettin a considerable amount of fuel in my oil and so I've been changing it every 300 miles. Figure it could only possibly be two things: injectors or afpr. I have 50# injectors, a 50# ultimate chip and a year old ATR afpr. I just installed a new afpr and took apart the old one. Other than some rust on the spring and metal disk in the middle of the diaphram everything looked good (ie no tear or hole in the diaphram)
Before I swapped out the regulator, I had a good reading on my fp gauge (pillar pod) and the fp would rise with the boost. I've heard people saying that after they turn off their car the fp stays where it was, my gauge shows it going back to zero immediately (this could be a dumb statement considering it's an electrical gauge, just throwing it out.) Anyone have any ideas? TIA
Jason
SY756
Well, since you checked out the FPR, the only thing that I can think of is a stuck injector. How's it running? Cause, those are the only two things that can get fuel down into the engine.
AlaskaTy
bezerk said:
it could also be that you are running way to rich with the #50 injectors...
I thought about that, I have a stock turbo, but I thought 50# injectors were like stock just capable of more flow ie: they could flow what I ask up to 50#s. Maybe I'm wrong here.
Maybe this will help: at first it ran great when the fp was set at 39#s (at this setting there was no fuel in the oil) and then I bumped it up to 45#s and then I began to run super rich. Well I dropped the fp back down to 39#s and it's still running rich. It runs okay, but I haven't gotten on it b/c I want to keep my fp down (fp still rises with boost). After the afpr it can only be a stuck or blown injector right (they're only about 8 mo old with 3k miles on them).
bezerk
well, if you have been running way to rich for a while, it would cause damage... still i think there is no need to be worried...
you can run with 50lb injectors with a stock engine, just get a chip that is good for those injectors (wich you have)..
the best way to check everything out is to; get the injectors tested (maybe someone is leaking, cause you have problems with holding FP while engine is off..)
the AFPR ain't a problem, maybe it sends to much feul to your injectors, but still you have a FP monitor.
you should get a compression check also.
another check with datamaster, see if you run to rich..
AlaskaTy
This is a new build and everything checked out at 39#s fp. It was when it was turned up to 45#s that it started misbehaving. I guess I'm gonna pull my 50#ers swap in the stock chip and that should fix everything. then I can flow test the 50#ers. Thanks for the input guys...at least I know I can run the 50#ers with the stock turbo.
myclone
FWIW... Seems Ive heard/read that ppl using the 50lber chip/injectors are running 34-36psi of fuel pressure. I cant quote any particular thread but I remember BG discussing fuel pressures when his 50lb chip first came out and I could swear he said start at 36psi of base FP on the 50lbers. It also seems like some ppl chimed in and said their trucks ran better at a little lower or higher base FP depending on their mods.
Anyways, it sounds to me like your FP is set too high and its drowning the motor in fuel. If so then it can cause serious damage if left that way as things like the rings, cylinder walls, and bearings get washed down and start to scuff which is bad.
HTH some..
AlaskaTy
Well, I guess I'll be dropping my fp to about 34/35. I haven't ran the truck with the new afpr, but I'm gonna run datamaster. I'm guessing datamaster won't tell me if I have a stuck injector. I know that excess fuel will destroy an engine (already had a buil rebuilt) so I'm changing the oil everytime I smell fuel (about every 300 miles)....Good thing is I've gotten changing oil down to a science :D
cloneman315
yeah mine did same problem turned out it was the ultimate chip way to rich at ilde truck ran at 15 psi fuel presure changed the chip out to a custom one and problem solved idles absolute perfect 750 rpm no a miss rock solid tach :D
AlaskaTy
**Update**
Although the old afpr looked fine when I turned off my truck the fp would fall to zero instantly. Now with the new regulator the fp stays where it was! So I'm gonna go run datamaster, see what's going on inside and give my oil the 'ol sniff test.
AlaskaTy
The oil still smells like fuel (but I'm going to change it tomorrow and hope that it doesn't get any worse) and I've swapped out my afpr with a new one. I ran datamaster: I was getting pretty gnarly spark retard under boost (up to 8.6* at 12.3lbs). For the most part it wasn't knocking, but when the boost started coming on strong it would retard about 4-6*. O2 counts were between 800 and 900 (but I saw it dip down to 100?)
Can someone take a look at my run and shed some light into what's happening? TIA
Jason
AlaskaTy
This sh*t is slowly killing me!! I put the stock injectors in and went with the stock chip and 2 bar map. I haven't done a leak down test, but my compression test through three rotations was dead on (130-140 in each cylinder). What else could there be? This things my daily driver, so it really sucks having to change the oil ever week because I don't want the fuel to thin it out.
ed hess
race or get outta the way
fwiw
when i had 50# and ultimate chip after making runs at the track i would allways have to add a qt or at least half qt the next day. I kept thinking the motor just wasnt going to seal. now that we are using dfi and a custom tune oil consumption has disappeared. the motor had about 3-4 k on it when we changed to the dfi. daily driving didnt consume oil. only wot did.
so with the stock injectors and stk chip did your problem go away?
ed
AlaskaTy
cloneman315 said:
ill bet everything i own its that 50 chip they r junk
But I don't have the 50# chip in anymore. I've gotten a new battery after I swapped the stock chip in so I'm sure the ECU had time to clear itself. I'm not consuming any oil, the problem is that after a driving it a while the oil starts smelling like fuel. I don't know much about compression tests and leakdown tests, but if my compression test was good, wouldn't that rule bad rings or a bad ring seal? Another thing, is that it smells a lot like fuel down by my charcoal canister (I have no idea what the charcoal canister does...maybe emmissions?).
kwick6
I have a set of 50's on the way, chip sitting here for them waiting.
Would I tell the average joe to throw 50's on his truck and run with it, nope. But add scantools, WB02's, and some chip skills.... and you might find its not the chip, but the guy that can't tune thats the real problem.
cloneman315
true tunning is a big part but i def am sure that them 50 pound chips are junk no ?s about that. u def need to do a wbo2 custom chip to get full potential
ed hess
nah, burn chips! old hat man.... everyone i hear is going to gen 7 w/wbo2, msbc, dual line lock and a thm400! :D
ed
