Fuel injector leaking ... fuel.
Gimpster
Gimp Extraordinaire
Today I noticed my front passenger side injector is leaking fuel. The entire injector from top/bottom had a nice coating of fuel and evaporated fairly quickly after turning off the truck.
I believe this is the #2 injector?
My question is: can anyone point me to a fuel injector oring / seal kit? I went to a couple of the parts stores around here and of course the only thing that had in their books was TBI stuff. Would like a TPI 350 injector seal kit work on this rail? The injectors look about the same form factor as a TPI from memory.
From old posts on here it looks like the previous owner had 50#'s in it at one time, so I'm guessing he reused the old orings when reinstalling the stockers.
EDIT: Boo, I fail... found this thread searching with better terms: http://www.syty.net/forums/showthread.php?t=49099&highlight=fuel+injector+change
Gimpster
Gimp Extraordinaire
Re: Fuel injector leaking ... fuel.
Well... that'll do it :sly:
I'm scared that even though I've only owned the truck like 10 days, I had them out in like 30 minutes. This is going to be an interesting truck to own.
main.php
main.php
gkrcr882
SyTyless......for now!
Yikes. While you have them out, might be worthwhile to get them cleaned/flow matched as well.
Gimpster
Gimp Extraordinaire
Funny you should say that. I asked around my local car forum, and we don't appear to have anyone local who can clean/flow match.
Is there a vendor on the board or someone else you could reccomend?
I'm particularly interested in doing that because I found an old post by the previous owner. In the post he said he had a stock injector that wouldnt close fully. I'm hoping he didn't, but its possible he put them back in the truck when he pulled the 50#'s. I doubt he did, but stuff happens you know.
