jjorgensen52
NHSTE - I'm the only one!
Does anyone know, since I need to replace my fuel lines, if there is any difference between a typhoon's lines and those on a regular 2.8L jimmy? I found them in stainless, but they only list the 2.8L
I'm 100% porked here, because one of my Ty's had a blown up motor in the back when I bought it, and included, was a slotted fuel rail. The intakes could have come from the Ty, or maybe a donor Sy. My other Ty also has a slotted rail, but it has 140k on the clock, and almost seems to run too strong and well to be the stock untouched motor; could have been another donor Sy, but haven't dug into it. Anyone else?Jimmy said:From syty.org
The trucks normally have a loud pulse from the injectors, so this is normal. But if your truck is clearly making a ticking noise louder than usual, you may have to adjust the height of the fuel rail. Earilier model trucks will have a slotted design rail in which you will have to loosen the nuts holding the rail onto the manifold and slide the rail in an upwards motion, careful not to ground the injectors on the intake manifold. If your rail does not have slots, but pre-drilled holes, you will not have to adjust your fuel rail height and should diagnose the source of your injector tick further.
Sy's have the slots,Ty's don't.![]()
There isn't very much left of my lines.... hence the need to replace them... about 1/3 of it was already rubber hose where it was leaking / brokewarmpancakes said:send the line to inline tube they will make them for you.
