Fuel Management Controller...?
Re: Fuel Management Controller...?
No its not a good idea. At 15 psi your Fuel pressure will be up 60psi over base pressure. For instance stock ~42psi for a total of 102psi of fuel pressure. A stock Fuel pump won't handle this high and I am not sure if the injector will either. This is inteneded as a band aid to ECM tuning for low boost supercharger aplications. A lot guys when they get up around 90-100psi have to spend a bunch of money on dual pump setups to handle fuel supply for relatively moderate setups, something a $100 Walbro can easily do at lower pressures..
