fuel pressure gauge adapter
jpalmer
need a part number to get my fuel pressure gauge to attach to my fuel rail on my sy. Its a summit brand one with 1/8" npt male.TIA
Loeryder
Re: fuel pressure gauge adapter
whipple used to make a fitting to install the sending unit on the fuel line under the drivers side frame rail.
out of sight out of mind.
Whipple Industries sells a "fuel pressure test fitting" which will allow install of the fuel pressure sender in the feed line under the truck. The fitting (3/8 Saginaw male-3/8 Saginaw female) installs between the hardline and the fuel hose right near the front body mount. Simple and stealth. To order, contact Whipple Industries, ph (559)442-1261
Cost is $15.
Syclone1639
I am also looking to place a fuel pressure gage under the hood mounted on the fuel rail. Can anyone put me in the right direction?
Sy+Ty
Buy one of RPM's B/S fuel rail hose adaptors! Has the correct fittings on each end & allows more mounting/placement options for your gauge. (Also minimizes the stress on our supposedly fragile fuel rails.) Then just buy a small, liquid-filled gauge from Summit for <$20 or so & be done w/ it.
At least that's one way to do it...
jpalmer
^yeah ill have to try that, there is nothing that is a strait adapter in an fittings
spooldup
Super Member
the whipple fitting is 35 shipped but definitly the cleanest in my opinion. 35 is a rip but nobody makes the thing.
