Fuel pressure gauge install help
2500avalanche
Well-known member
Hello,
I am having some issues installing my fuel pressure gauge. Yes I have the sender and the gauge. I have the line so it doesn't sit on the fuel rail. Gauge will be on the pillar. Just having issues with the wiring. Directions are hard to understand. Any pics would be great.
Thanks
Brwndrvr05
Re: Fuel pressure gauge install help
what did you buy Autometer? If so, off the top of my head, red is power, black is ground, and i believe white is for the lighting. Post up pic of instructions and we can clarify
2500avalanche
Well-known member
I use Stewart Werner guages. I think I have it figured out.... Just a little confused! From the look of it it has 3 posts on the back of the gauge a +,-,S. BUT it also has a light bulb with a + and -. The S goes to the sender, and I guess that is where I am getting confused with the sender because it has the letter G on it where the S from the gauge would go
Aeroking
e.i.
if the gauge is 1 wire marked S. I would assume that's to the Sender, And the sender 1 wire marked G. I would assume that's to the Gauge. So connect them together, maybe. Instructions should have a wiring diagram.
