fuel pressure goes away
Falco
Those of you who have a mechanical FP gauge could answer this question. Do you loose the pressure slowly after shutting down the truck? I lose all my pressure in an hour or so. I have good pressure under boost, so just wondering it's a problem or not.
I guess I know how to test to localize the leaking component (operating the pump while clipping different rubber sections in the fuel lines), but this might be normal.
TIA,
V6 Kompressor
There are four things that can cause this... The fuel pressure regulator is leaking internally, allowing fuel to flow back to the tank, you have an injector leaking fuel into the engine (Usually produces black smoke and rough Idle upon start up), fuel line leak ( You would smell fuel vapors) and internally in the pump's check valve. My wifes 95 blazer has been doing this scince I have had it, it is leaking by the regulator ($350), and the only thing it is causing is sometimes it takes a little longer to start, because the fuel line has to charge to full pressure for this engine to crank. Do you have any problems with performance or starting?
Falco
Thanks for the relplies. I just made an injector balance test, they worked fine, and she is not smoking at all. So I ruled out injectors I guess. Can't smell any odor around. My AFPR is a year old KB one, hopefully it's not the problem. My first susspect is the pulsator. When I changed to Walbro I left the pulsator in. Will drop it away and use the hose supplied in the Walbro kit instead.
I've performace problems, not a huge one, but it should be some 0.5 faster. No hard start problem even when I let her sitting for a while.
Peace,
