in an attempt to find my stalling/rough idle problem today i checked my fuel pressure. Base fuel pressure was jumping between 53-52 PSI really fast. Vaccume line on it was at 48-49 PSI also fluttering very fast between the two. The fluttering is just like my tach flutter and sometimes it will put out some white smoke idling (rich). I've heard that 42PSI is stock base PSI. My truck is completely stock with a new MAP sensor, coil, conrad cap and rotor, cheap wires (soon to be changed), cr42ts's, k+n in box filter, fuel filter, no vaccume leaks, and fresh oil change. I have severe tach flutter and sometimes there's a quick intermittant (random) miss like a wires arching out occasionally but not all the time. It also stalls alot when first put into gear (like backing out of my driveway). Any help?? I want to fix ASAP...
Thanks-
Mike
93 ty #0731
black/grey - stock
Thanks-
Mike
93 ty #0731
black/grey - stock
