fuel pressure not bleading off
Flyin Ryan
hated cuz he drives fords
got a question, currently have have a fuel pressrue gauge mounted on the fuel rail. I know... have a digital electronic gauge but haven't installed it yet..
anyway my question is that i'd always noticed that the fuel press would eventually blend down after time but lately i've noticed that it's not blending down.. could this mean my fuel pump is on it's way out??
Thanks
Ryan
ItsMyTy
Life is beter at 25 PSI
could be
bad fuel pump check valve (internal in the pump)
bad pulsator diaphram leaking intermittantly
bad fuel pressure regulator diaphram leaking intermittantly
bad fuel pressure regulator, causing leak back thru the return line
bad fuel injector leaking into intake/combustion chamber
you'll have to perform some more diagnostics to determine which it is. a leaking injector or regulator diaphram should cause other drivability problems... like gas in the oil, running like crap when you first crank it up after sitting for a while, etc. a bad regulator leaking into the return, bad check valve in pump, or pulsator leaking a little might not cause other noticeable problems besides fuel pressure leakdown. If you've got the stock pump and stock regulator, you should get a walbro and new adjustable regulator and get rid of the pulsator and see if you've still got a leakdown. that's what i'd do, anyway
hth
Flyin Ryan
ItsMyTy said:
could be
hth
okey, I checked my oil and it doesn't smell of gas.
Vac line to afpr doesn't have any trace of gas in it.
sorry i didn't mention what pump and reg I have.. well I have a walbro pump and atr afpr. The pump has two years on it and the afpr has a year or so on it. Im thinking it's the pump but haven't had any kr while in boost over 2 degrees in dm which is normal for my truck. I haven't seen any changes in how shitty it idles over the past weeks and yes this truck is daily driver :roll:
hmm maybe my liquid filled gauge on the rail is fudged up? anybody ever seen that before?
GM TURBO
Sell Out
I just want to make sure I am reading this correctly...
You're fuel pressure isn't bleeding off when you shut the key off?
Isn't this the way its 'sposed to be?
Flyin Ryan
yes but after sometime shouldn't it blead off?
Lynn D. Brown
FP bleeding off
FP bleeding off
Not really. In a "perfect" world, it won't ever bleed off if the seals are perfect. It's just that they are rarely ever perfect, so it eventually does bleed off.
I don't see why anyone would want to have it bleed off. If U need to work on it, U just drain off the pressure at the Schraeder valve.
Flyin Ryan
Re: FP bleeding off
Re: FP bleeding off
okey so your saying something is actually working the way it should?? :D
good then I will not f with it.. i just noticed that it did bleed off before after a few hours but now it doesn't sooo i was just concerned.
