Fuel Pressure Question?
UK-Ty
Ty Crazy
I fitted a fuel pressure gauge today and it was running at 43psi at idle which is ok but when i turn the engine off the fuel pressure drops quite quickly. Is this normal as i thought the pressure would stay in the system?:dunno:
Ty 1885
Re: Fuel Pressure Question?
You have a leak somewhere ! Check the gauge connections, pull the vacume hose off FPR , any fuel in it, if yes then its leaking, also check fuel rail for leaks, if thats okay, then you have a one or more leaking injectors.
bezerk
it can also be in the feulpump. i had this problem, swapped injectors. and still have the problem. i woudln't worry about it if you checked for leaks outside the system.
SY2932
Administrator
Barring any obvious leaks from lines or hoses, it could be the fuel pressure regulator, an injector(s) stuck open or a fuel pump problem. DaveP detailed the troubleshooting process in great detail in post #52 of this thread.
blazinmt
What is normal for fuel pressure at idle? What is acceptable fuel pressure drop after shutting down?
