fuel pressure testing
SevenT6Vet
I borrowed a fuel pressure tester to check the phoon. What kind of tests should I do to check things?
I turned key on, pressure is 43.
I turned key off, check valve kept pressure at 43, no pressure drop.
Vehicle idled with constant pressure.
unfortunately hose is to short to go and drive around with it connected (if that is even something people do).
stock fuel pump good to go or is there other tests i can do?
93 with 91k miles, all stock except catback and drop in K&N.
Matt
Re: fuel pressure testing
make sure you check pressure with the vac line unhooked it should be around 42 psi but it seems ok from what you explained
