Fuel pressure & tuning
AUSyTyIN
Unbusted $#it box
First the mods: AFPR, warlbro 255, shurflow, turbo port matched, K&N cone filter, solid turbo to CCHE pipe and thats about it. So, nothing major. When I got the truck, the AFPR was set at 37 PSI (vac. plugged). O2's were in the mid .700's. Knock up the @$$. I've been raising the fuel PSI slowly but I'm at 46 now, and O2's are still only mid .800's, and still knocking. Some of this knock is comming from the TC that is on its way out (one on the way), but that can't be all of it, can it? I've reset the ECU by pulling the fuse out for a few min., and still no change. What else can cause this? Should I keep raising the pressure?
leroy
Re: Fuel pressure & tuning
How new is your O2 sensor? It may be getting a little lazy.
Jim
Tooky
Serious about performance
Do your spark plugs look white, or dark and sooty?
AUSyTyIN
Unbusted $#it box
New plugs, cap, & rotor. Will replace the O2 sensor. I know O2's are supposed to be in the 900's, that is why I am posting here. Any other ideas other than raising fuel pressure? Isn't 46 PSI higher than most trucks with similar "mods".
Tooky
The reason I asked the color of your spark plugs is so you can get a feel for how the truck is truly operating (despite what the electronics may tell you). For example if they were white you might conclude the O2 sensor is reading accurately and you honestly are lean. Or if they were filthy black you might conclude the truck is already pig rich and the O2 sensor is faulty.
AUSyTyIN
Unbusted $#it box
I understand what you were saying. I'll check them when I have a sec.
