i wired up my fuel pressure gauge, and i was wondering where the power source for the fuel sensor off the gauge gets wired to? Theres a positive and negative wire . Does it get wired under the dash somewhere?
you can either tap the fuse box or tap your 12 volt switched for your radio
There are some empty slots labed as "ign" in the upper leftt corner of the fuse box. Use one of those. That will turn th gauge on with the key when you turn truck on. Just climp a male spade connecter to the red wire and plug it in. I ran my ground wire to the 10mm bolt under the dashboard near the fuse box
