I know this doesn't pertain to most of you on here but thought it might post some good information that has not come up in my searches.
Anyway... As some of you know, my SoGT was loading up at NATS and I never made a decent pass. The best being a 16.1 and I was hoping to at least be in the 15's. A couple guys helped me out to diagnose the problem and it appeared that the fuel pressure was too high. Well, I have a different set-up than the SY/TY's (not any better for sure) and more pressure is required. I have little poppet nozels going to each cylinder that require 50lbs. just to open them up so the 60lb reading we got wasn't bad. It turns out that it was the very early stages of going bad. This is a common problem with this set-up and often requires replacement anytime after 75,000 miles according to some of the S-Series members. How fortunate was I to get 162,xxx out of mine. I knew about the possibility but it seemed to be fine before the Vortec upgrade. I guess with the highter flow from the Vortecs and headers it became more noticeable.
The assembly runs around $300 but I was lucky to find just the regulator for $40 (it seems this is the part that fails). I ordered it imediately and hope to have it by the weekend. Once I get it installed and make a few street passes I'll let you all know how it went. Maybe I'll make it to Gateway a few times this year?
