fuel pressure
NecroWolf
lost marbles member
well i finally broke down and bought a fuel pressure guage. hooked it up and with the vacum line unhooked i get 50lbs of pressure, with it hooked up i get over 50lbs. now aren't these trucks suppose to idle with 42lbs of fuel pressure? so this means i probably should buy a apfr now?
QUICK STORM
B.A.M.F. BMW Tech
Re: fuel pressure
buy an adjustable one then check it, could be a bad diaphragm in the old one causing a leak.
NecroWolf
lost marbles member
Re: fuel pressure
i've noticed it's been running rich lately and getting lots of flood smoke when i punch it, i hope this cures it or makes it better and maybe it'll improve my gas miliage. i only seem to get 10 mpg crusin around town.
SY2932
Administrator
Re: fuel pressure
Fifty psi is WAY to high for a truck unless you are running a custom chip and a 3 bar MAP sensor...
NecroWolf
lost marbles member
Re: fuel pressure
yeah it's a 2bar w/ a pitbull chip. okay wonder who can get me a afpr here the quickest
Re: fuel pressure
Something is definitely cockeyed here. FP is supposed to go down when you attach the vac line. You’re doing this at idle I assume? When you add some power does the FP rise a little to follow (less) vacuum? Detroit Turbo and RPM both have the good AFPR’s. They can prolly ship overnight for little additional on that small an item. Well worth the effort.
NecroWolf
lost marbles member
Re: fuel pressure
well with the line hooked up i see over 50lbs and without it i see almost sixty
NecroWolf
lost marbles member
Re: fuel pressure
got a new fpr, couldn't afford an afpr with the new baby but fp is now 43ish. and the truck seems more responsive and doesn't puff out as much flood smoke when i floor it.
QUICK STORM
B.A.M.F. BMW Tech
Re: fuel pressure
run some high octane gas or octane booster and burn out all that rich mixture you got in the truck.
SY2932
Administrator
Re: fuel pressure
Depending on how long you drove the truck running pig rich like that, it may be in your interest to change the plugs (if you're ambitious that is)...
QUICK STORM
B.A.M.F. BMW Tech
Re: fuel pressure
agreed:tup:
