Fuel pressure....
ircwet
Well I have done some seaching and cant get a constant value...I have some knock issues at WOT...(like who doesnt')...my current Fp is 54 with vaccum unhooked....and line plugged. With vaccum hooked in it is at 42. I redtop injectors//(stock?) and stock F/P.
Looking for suggestions....or am I close to were I want to be ? Thanks Dustin
LandryPoole
Re: Fuel pressure....
Change the fuel pump. It probably is not doing a very good job keeping up with fuel demands at WOT. Especially since you are demading more from it now.
ircwet
not really into changing out fuelpumps....Just wanted to know what the STOCKERS' are running for Fp.....
LandryPoole
You can change the fuel pump inside of 3 hours easy. It is not hard to do at all. This is a good time to take out the rear stabalizing compressor as well, if you are not using it, which a set of Bilstein's will remedy just fine.
SY2455
70's Veteran
If you are still running the stock fuel pump, you should change it out with a pump upgrade. The reason for doing this is the stock pump was at the limit of it design pumping cap. From what I have found it's running at 85 to 90% of what it design to do with a stock engine. Changing the pump is cheap insurance for your engine. I'm running a Walbro 255 from http://www.raceprovenmotors.com/cart/index.php?cPath=44_74. I set my press at 45psi.
