Bill Z
I have this technical fuel pressure question.
If the electronics of the ECM vary the pulse with to the injectors so they spray more or less fuel into the engine, then why does the fuel pressure regulator have a vacuum connection that adjusts the pressure?
It seems to me that with a constant fuel pressure the pulse with should be sufficient to run the engine at all RPMs.
What would happen if I set my regulator to, say 35 pounds and kept the vacuum off?
