Injected1
Ok so after finding out that the fuel pump I purchased was for a carb motor (12psi) I replaced it with an aeromotive a1000. I have braided 8an line from the cell to RPM's fuel rails, 75# injectors, Aeromotive AFPR, 6an return to the tank. After hooking up the fuel pump today I started the truck adjusted the regulator to 45psi and the AEM afr was reading 10.6 at anything over idle but the truck was dumping fuel out the exhaust. It actually ran smoother on the 12psi pump, It felt like a miss at anything over idle. Is this a chip issue most likely? I am using the "MARIO" bin file that Mike Hood tuned I believe. We have almost the same exact build but I will list it for those of you that want to know. What do I need do from here?
4 bolt main .030, TRW l2441, eagle rods, nitrided crank, 415 cam, vortec heads, comp valvetrain, 75#'s, pte 67, synapse WG & BOV, Custom A2A, 3600 yank, RPM race 700r4.
Shooting for high 10's!!!!!!!!!!!!!!!!!!!
