fuel problems still!!!!!!!
imposters
Hi I am getting gas in my oil still......I replaced the injectors and reg.. Each piston, are filling up with gas. I am not touching the gas padle at all.
I am lost :roll: !!!!!!!!!!!!!!! The motor isn't broke in........... I have been fighting this for about 4 months now. could it be the 3 map ???? I put a diff. chip in it all ready. I just tryed to start it today ofr around 15 min and got 1-1/2 gallons of gas out of the oil pan......
Thanks ANdy
AlaskaTy
I'm also getting gas in my oil, but I haven't pulled my injectors or chip yet (I'm gonna do it this weekend) There's only a couple things that can be causing this to happen: injectors, fuel pressure regulator, and chip. If you've replaced two of the three (and with good parts) I'd swap the chip to stock chip and see what happens. Also, someone told me that when they were running rich they pulled the ECM-B fuse for a while so the ECM could unlearn what was causing the rich conditions - didn't work for me but it's worth a shot. Good luck.
imposters
yes that is a problem!!!!!!!!!!!! Alot of gas for a little time to get it started... OH thats right I didn't get it started!!!!!!!!! It tryed........
AlaskaTy
DanenGraham said:
1.5 Gal of gas in the pan!!! good lord.
yeah, I'm not nearly that bad, so it might be something extreme like your fule pump is hooked up to your oil pan? Sorry, other than swapping the chip to a stock chip I don't know what else to say.
