GMCSyclone1
NASTE MEMBER
I went up to the Nascar races this weekend in Dover and I noticed a few problems on the way back. First my abs light came on but when I checked the brake fluid it was basically dirt so I am gonna change that out and hopefully it will solve that prob. The real problem I'm having is that the truck wants to die out whenever I smash on it. If I ease on the throttle it takes off fine but once the pedal goes to the floor the truck starts to sputter like the fuel is being cut. I noticed it the first time at about 40 to 80 around 80 it started to sputter it did the same when I floored from 80. I decided to smash it once from a stand still and once from a launch both times same issue truck takes off then its like the fuel cuts on me. I just installed a Walbro 255 and I had over a half of tank so I doubt its a fuel slosh prob. especially since it does it from a roll aswell. I don't know if it is something in the ECU or if its a boost problem. I'm not sure exactly where to look first. Does anybody have any ideas? Thanks for any help.
