syclone#2659
what should i run for fuel pressue with the pittbull chip? i have 40 lb injectors (i know this set up is no good , but im broke till spring, then ill get the ultimate 50) id like to maybee run 17 psi tops, i will be running high octane for this weekend, so i was curious where i should set the fuel to make up for the 2.3 lbs of boost that i wont fuel for :wink: maybee i will stick with 14.7 lbs of boost , but i id like to squeese a little more if i can
