Fuel pump? No, But trouble found
wildphil
I Love My Ty's
I drove the Ty around for a hour or so tuning it. Its running really well.
A little while later I left the house to pick up a oil filter for the daily driver so I took my Ty.
After driving about 2 miles it started running rough the AFR gauge went lean and the truck died.
It would restart and then die in in a couple of seconds.
Finally it restarted and after dying a couple of times. I got home with it.
After I got home with it I ran a jumper to the wire that will run the fuel pump. I could hear it run. Part of the time it sounded normal part of the time it made a squealing noise.
I am guessing that is the problem.
What do you all think?
It has is a Walbro with less that 2k miles of use. The fuel filter about the same.
SY2932
Administrator
Re: Fuel pump?
Re: Fuel pump?
Sounds like it is time to drop the tank again... Did you get the pump from a known good vendor or was it a cheap ebay special? Running for 10 years plus on a Walbro that I bought from Ron Gregory's website APE.
wildphil
I Love My Ty's
Re: Fuel pump?
Re: Fuel pump?
The truck started right up today.
But I had a new spare Walbro I picked up from a fellow member that I had planned on using on the blue truck. He bought if from a reputable source.
I installed it and a new fuel filter. Hope that takes care of the problem.
wildphil
I Love My Ty's
Re: Fuel pump? Problems after new one
After the new pump was installed. I started the truck and just set and let the truck run to see if it would keep running.
Right after I started the truck I looked at the fuel pressure and the gauge was on 45 psi
I drive the truck a couple of miles and about 1/4 miles from the house the truck started to run a rough but smoothed out and I noticed the fuel pressure was over 80 psi and when I pulled into the driveway in was almost 100 psi.
I turned the truck off and restarted a couple of minures later and the gauge still read about 100 psi.
What in the world is going on.
Is the new pump just working better and I just need to adjust the fuel pressure?
Is this one screwed up to?
Why did my truck start to run rough again? Is something else causing this problem besides the fuel pump? Or did it run rough this time because the fuel pressure got so High?
High pressure is cause by an obstruction on the return line. I supose if the bladder in the adjustable regulator ruptured and block the return it could be that as well.
I also found out last week if you electric fuel sending unit for a fuel pressure guage is resting on the tire ands wear away the wire the guage will read start jumping high and eventually read 100psi.
wildphil
I Love My Ty's
I think you may be right on the money about the fuel line. Especially if the return line is the inner line. I had a hard time getting it to reach far enough to get it started to screw togather. So I went around to the side of the truck and popped the line out of the rubber bracket to get a little slack.
I am guessing the rubber line slipped under the upper strap for the gas tank when I did that and I didn't notice.
Then when I bolted the gas tank up it pinched the hell out of the rubber line.
I guess I will find out if a few days when I get a chance to work on the truck.
Thanks for the idea. You probably saved me a lot of time.
wildphil
I Love My Ty's
Got the fuel pressure reading correctly now. Sure enough the return line was pinched.
I let the truck idle for quite awhile after that was repaired to see if the truck was going to start running rough. Truck ran great at idle. I didn't take it for a test drive to see how it would do.
I will take it for a drive tomorrow. Sure hope the new fuel pump corrects the running problem.
wildphil
I Love My Ty's
So far so good. I just drove around the neighborhood today. It was looking like it was about to rain. I sure didn't want the truck to quit running and be stuck out in the rain.
It ran fine today. Maybe tomarrow I can drive it a little longer to see if it is fixed.
wildphil
I Love My Ty's
Re: Fuel pump? No, But trouble found
I believe the problem with my truck is cured.
Just before I left for a drive to see if the truck was going to be ok the truck died. After restarting the truck I just started moving wires under the hood. I found a wire at one of the connectors that plug into the coil broken under the insulation.
It least I hope that was the cause.
