Im troubleshooting a situation on my Ty where the fuel pump won't kick on when I go to start the truck up. If I connect 12 volts to the wire by the distributor, the pump does turn on. I've also swapped relays around with the same no kick on results. I've checked the voltages at the plug and sometimes I get the trigger wire voltage, sometimes I don't. I checked that with the 12 volts to that wire by the distributor. The only thing I can think of is the oil pressure sometimes shows pressure when cranking and sometimes it doesn't. If the truck is running, it does show oil pressure. If I try to run the fuel pump with the relay only, it shuts off as soon as I take power off that testing wire. I've already fried a borrowed ECU, and I'm not really wanting to fry another.
Things I've changed is the whole distributor, coil, new plugs, and added more grounds directly to the alternator casing. I thought I fixed it when I added the grounds, but the next day it refuses to start no matter what I do. I've checked all of my grounds and they are in good shape and hooked up. When it did run, it ran great, super smooth. One thing, when it was running once, I opened the door and the lights dimmed and the CEL flashed on for a second. Hence why I added and checked grounds. Fuses are all good too.
Is it even possible that my new oil pressure sensor works intermittently? I'm not good at troubleshooting electrical stuff to be completely honest. Any ideas??
