Fuel pump sucking air?
gto2003
So... I have been fighting my truck since i got it tryin to get it running right.. I have replaced all kinds of stuff and couldnt figure it out until yesterday. I realized the cap on my IC was loose because the previous owner has bent up the locking tabs and it must have come loose (and the heat exchanger was nearly empty). So now that the truck is running better (havent scanned it yet) when i get on it for a few seconds it seems like the fuel pump is pulling in air. I went to the gas station and put $20 in it thinking that it would take care of it. Now the truck is reading 3/4 tank and still seems like it is sucking in air after a few seconds of WOT. It pulls really hard then Very Suddenly it has NO POWER. The first time this happened i thought it may have died. The only real mod to the truck is a Walbro 255 pump. What could be causing this? I put a fresh fuel filter on it ~7k miles ago (cheap one from advanced auto parts)could i be out flowing the limits of the filter?
Could this be a problem with my fuel pressure regulator? Crappy fuel filter? Cavitation? Has anyone ran into this before?
gto2003
Re: Fuel pump sucking air?
Check vacuum lines and plug gaps and wires.
Have, Plugs are new, Wires are fairly new, fresh cap and rotor (5k miles), and the only vacuum leak i can find is at the throttle lever. By the gauge the truck shows 10ish psi vacuum at idle.
graham1524
Well-known member
Are all of the lines intact on the fuel sending unit? that happened to me and took forever to diagnose
Also if its a small leak around the throttle lever I found to be sort of common also have it on my truck
Owned
Get datamaster asap before u blow it. stop wot, until u can read whats going on. :2cents:
sy#2716
SyTy 4 Life
thats one problem you have a vaccum leak if you only have 10psi of vaccum it shold be around 18 psi or so on a stock cam. Even my 422 cam pulls 14psi of vaccum at idle.
gto2003
I think you mean in/hg (inches of mercury) not psi. Full vacuum in PSI is 14.7. if you convert my 10 psi to in/hg you get roughly 20.
gto2003
What do you mean by the fuel sending unit? Are you talking about the fuel pressure regulator? Or back by the tank where the lines hook up?
gto2003
I only did it twice.. once when i fixed the low coolant in the reservoir and once after i filled it up to see if that corrected it. It really feels like when the truck is really low on gas and it pulls in air i just dont know why or how it would be doing that.
Also i have the cable (moates.com) i just need to get the software loaded.
gto2003
Sounds like the ECM is pulling timing. Knock, knock, knocking on heaven's doooor.
no.. its been pulling timing since i bought it. This is like the truck just completely turned off. I actually thought it died the first time.
SY2932
Administrator
Inside the tank that connects to the fuel pump
Yep, you can see a post about this problem here.
The pic that was originally posted in that thread isn't there anymore but this is what the fuel line looked like:
Bottom line is stay out of boost until you get it fixed.
Quickstop [UK]
Combating adversyty.
Is your filter in the tank getting blocked? Is it sucking and then sucking against the floor of the tank, starving you of fuel and then causing your timing etc etc?
As above - stay out of knock for god's sake or you'll kill it.
gto2003
I assume you've got an aftermarket boost gauge? Stock chip? It sounds like you're overboosting. No CEL?
i have a boost gauge but it isnt hooked up right now. i unhooked it when i was trying to chase down vacuum leaks and never spliced it back in. what is a CEL?
gto2003
OK... So i put a fuel pressure gauge on the truck. With the vacuum line hooked up it idles with about 42 PSI (vibrates between 40 and 45). When you rev the truck up though the needle vibrates between 40 and 60 ish (just a blur). The truck recently got a Walbro 255 pump from detroitturbo.com so i do not think that is the problem. When you turn the key off the truck doesnt seem to lose ANY fuel pressure so i dont think it is a problem with the rubber line in the tank. Initially i thought the problem was the gauge so i hooked it up to another car and it was nice and smooth like it should be.
Do i need to invest in an AFPR?? what does everyone run on their trucks?
I searched the forums and the only one i found that has a resolution seemed to be the fuel pressure regulator but he wasnt fluctuating nearly as much as my truck.
UPDATE*** I unhooked the fuel pressure regulator and it seems to have fixed the gauge bouncing around. If you give it a rev it stays pretty solid at 50 psi. Would it be safer for me to run the truck with no fuel pressure regulator until i can get a replacement?
AFPR is on the way. Hopefully this will take care of the problem.
gto2003
I think i have got it. I tested the fuel pressure and with the vacuum line unhooked i had 50 psi pretty steadily. When i hooked the vacuum line back up I had about 40 but when i gave it a rev it went nuts. it was bouncing between 40 and 60 psi. I bought an AFPR and dialed it in at 43 PSI with the Vacuum line off and the fuel pressure now goes up nice and smooth like its supposed to. I would to take it for a ride but.. its currently ice storming here. Guess it will have to wait until after i get back from basic training.
