Fuel Pump write up with images
ABOSS
Has anyone done a write of a fuel pump change with images, if not i will do it. I have done some searchs and all I can find is instruction but no images. I find that Images help a ton.
gib74
Re: Fuel Pump write up with images
A write up with pics would be great. I dont like the write up in the archives too much.
ABOSS
Thanks Jimmy, just what i was looking for. I will also do a write up i think yours is great but there is a good way of not damaging the fuel line .. use PB blast penatrating oil and good line wrench
ABOSS
I read that it would be good to remove the rear bumper to make it easter to access the gass tank fittings, if so can some one tell me if this is easy or nots and iof its worth the additional work?
QUICK STORM
B.A.M.F. BMW Tech
it too much work. you can remove the fuel tank as long as you take the time, and it helps to have someone help you but it is possible to do it your self. good luck.
ABOSS
I will be doing it alone and i will use ratchet straps to suspend the tank level. i have had tanks slip off of jacks when lowering them. well i will take lots of pic's
Jimmy
Banned
It's not my writeup.It's from former Ty owner Jim Soltz :tup: .
Quickstop [UK]
Combating adversyty.
The previous write up appears to be SY related and is different from a Ty?
I am planning on doing thjis as soon as I get my fuel hanger frorm the US. Loads of pics would be great....
Thanks guys :)
