91Syclone2918
Can a 340LPH pump be used without having to modify the return line?? I know with turbo Buicks using stock fuel lines and a 340 pump sometimes yielded high fuel pressure that you couldn't get to come down....Thanks,
True. At the bottom of this page is the relay set I use: http://www.casperselectronics.com/cart/index.php?route=product/category&path=46 It was much cheaper a million years ago.Make sure you upgrade your bulkhead wiring at the same time or you will have issues with running the bigger pump
