Is the fuel rail port size on a Typhoon 1/8th npt? I'm looking to add a fuel pressure gauge in the cab and plug the sensor in where my current oil filled gauge mechanical gauge is...
You're going to use a electronic sender, right? Anywhoo... You want an extension hose for the sender port, since setting the sender on there directly *WILL CAUSE IT TO WEAKEN THE RAIL AND BREAK IT OFF RESULTING IN A FIRE*.
