Fuel regulator o-ring..GRRRR!!!
SY2767
Is there a trick to installing a KB fuel regulator on a stock fuel rail? I have ruined the o-ring from my stock regulator and the one that came with the KB unit. I oiled it on the first attempt and no dice, leaked terribly because the o-ring seemed to large and pinched on one side it seemed. So on my second attempt i used GM silicone lubricant, looks like vaseline, same result with that! So i need a new o-ring (part number??) and some tips on how not to fuc it up for a third time.....
TYTILIDIE
METH HEAD
Re: Fuel regulator o-ring..GRRRR!!!
When I used to have that type I would be real careful and push it kind of side to side gently. Vasoline does work though, I even would use my own spit. It can be a PITA though I'll give you that.
Don't know what the KB reg looks like but,
a) Same o-rings that the inj's use. Should be available at the parts house.
b) When you install the regulator Make sure that it slides into position almost completely. The bolts only pull it in the last 1/16 to maybe 1/8. Make sure there is noting in the hole. Old o-ring pieces, whatever. Unlikely but make sure the new o-ring doesn't have a twist. Again don't know about the KB unit but normally the two flanges where the bolts are should pull up and stop. There is no way to tighten additionally. Make sure the reg doesn't have a crack in it somewhere. For me anyway, only after I install the reg do I install the return line. Your leak is not there is it? Much smaller o-ring and easier to mess up.
HTH
SY2767
HTH
There was no o-ring on the KB unit where the fuel line screws in, should there be? Its machined kind of like a metal brake line so i assumed one was not needed or there in the first place but no you got me thinking.............
leadfoot
There should be an o-ring on the piece that goes into the fuel rail.
The threaded bottom piece (fuel line )should be something like this and have a mini o-ring? <forgot>
As mentioned before make sure there is no debris in the fuel rail female port, and lube the $hit out of the o-ring. :squint:
If you trash the two o-rings that come with the regulator (assuming it came with a spare) make sure you replace it with the same size/dash #.
Good luck ! :tup:
Yup, one goes there. Just get the correct one.
