Fuel Tank Foam
Sy769
Anyone tried putting this in the stock tank to help control the fuel slosh prob?
Various sized blocks are available from summit and others.
I know it would have to be stacked around the pump and fuel level float
Maybe put something in to keep it in place?
I am going to put in the walbro before the nats and trying to figure out something to help.
V6 Kompressor
When you remove the tank to install the walboro, look inside, There should be a series of plastic dams to help control fuel slosh... There is room to put sections of the foam inside, but it might be a real pita to install it if your arm is average or above, because of the size opening you have to work with. A young persons arm might be just the right size. The only other thing would be that you need clearance for the float for the tank level gauge. The other thing that would help is try not to race with less than 1/2 tank of fuel... I found that 1/2 = 7.5 gallons in most ty's/s-blazers/jimmys. I think 1/2 was supposed to equal 10 or 11 gallons in a ty...
