SYCLONE#1531
'MOFOFAST
KINDA long.....
Just testing my truck out today and I was greeted with a stalled bucking back in forth. truck coasting back in my driveway..Right before this, I noticed today under boost my afrs were jumping around in the 14.5 / 15 range. not a good thing with the boost levels I run (25psi)... Ive got a walboro that I installed a few years ago from RPM. I also have 8an lines coming from transfer case to rpm rails. Just installed. Also fp is set at 45psi idol with Aeromotive reg... Could the larger volume fuel lines have killed the walboro. Or could it be the C16 that its submersed in all of the time??? I looked at my metal fuel lines that came off the truck and interior of metal line is over twice as small as the 8an line interior. Im also gonna change fuel filter since I have never change since owning the truck. my bad!! This could be the issue? This seems to be a sudden thing that has just happened.. I dont recall any afr issues upon my last test drives.. Truck always ran really strong. Could this be another bad walboro? Also the pump seems to sound different when it preasureises when ignition is turn on. Truck will crank/ run and fuel preasure is running 40 on gauge whith line connected. Do I need a double pumper with the higher volume lines ??Any suggestions appreciated.
A little about the truck for those who dont know..Mods on truck are stock long block and cam. 61mm rpm turbo and downpipe, RPM edelbrock intake, 60lb injectors, fmic, RPM multichip tuned for c16 . 3400 3disc vigillante. Truck ran a 11.70 with a 3lb launch. 7.50 1/8th last time at track with bad conv and stock intake. Im estimating it should run 11 0s to a 10.90s with the new set up.. Truck now easily launches at 7.5 to 10lbs with the Vigilante. True believer is you get what you pay for when it comes to convertors. I paid 280 for my old 10 inch and it caused me a transmission + the cost of conv. + what was really bad, I couldnt spool the turbo past 3lbs!!!! with the el cheapo conv..
Still ran the 11.70 with it though..
